Unity Editor version (if applicable): 2022.3.11f1
ML2 OS version:1.5.0 using open XR though MLSDK version: 1.9.0
I want to connect the PC and ML headset together so that when I post/get https requests made from this code provided below, I will run a python script and return an output back to the ML and Unity project. We have used a personal hotspot so far to replace the IP address, but we are trying to run this on a larger scale for longer time periods and cannot use the hotspot for that long. I wanted to connect the ML and PC via USB-C tethering using this manual. I unfortunately do not have an account to link the two. I have a router as well that I can use to connect, but without WiFi. I do not have an ethernet cable to connect the ML to the router. If anyone has a solution to the problem that might not require too much spending on extra parts, please let me know. Or, let me know if there is a solution and I will buy the parts necessary to solve the problem.
string gazeDataString; public TextMeshPro m_TextComponent; public async void GetCaptions() { //startRecording += 1; Debug.Log("get captions"); //m_TextComponent = GetComponent<TMP_Text>(); // Change the text on the text component. //m_TextComponent.text = "Some new line of text."; var client = new HttpClient(); var request = new HttpRequestMessage(HttpMethod.Post, "http://169.254.161.11:8000/optimization/upload"); // Convert the gazeData list to a single string (you might want to format it differently) gazeDataString = string.Join("\\n", alertSpawner5.buffergazeData); //gazeDataString = string.Join("\\n", alertSpawner5.gazeData); // Join with newline characters from alertspawner, //if need to clear data, can find a way to do that // Create a StringContent object with the string data var stringContent = new StringContent(gazeDataString, Encoding.UTF8, "text/plain"); // Adjust encoding and content type if needed alertSpawner5.buffergazeData.Clear(); // Set the Content property of the request to the StringContent object request.Content = stringContent; var response = await client.SendAsync(request); response.EnsureSuccessStatusCode(); // Txt file content responseJson = await response.Content.ReadAsStringAsync(); //this reads the string, if it is just a cog load variable change if needed cogLoadReturnedValue = float.Parse(responseJson); //refer to this in the optimization function //m_TextComponent.text = $"cog load returned value {cogLoadReturnedValue}"; // ReadStringInput(responseJson); //var authResponse = JsonUtility.FromJson<videoInfo>(responseJson); //textMesh.text = authResponse.captions; //speechBubbleText.text = authResponse.captions; //startRecording += 1; Debug.Log("COUNT BEFORE: " + alertSpawner5.gazeData.Count); //WriteString(gazeDataString); alertSpawner5.buffergazeData.Clear(); Debug.Log("COUNT AFTER: " + alertSpawner5.gazeData.Count); //could technically add updateoptimization here }
