What is the best way to control and clean up old versions of the OS and sample code? Do we just go into the MagicLeap folder and delete individual folders? It would be great if the package manager can properly remove the unwanted old versions and download them only if the user selected to do.
Hi @rick, thank you for the post and I've logged your feedback. You can delete the unwanted versions through the Package Manager individually. For future ref, you can always select the "Remove old version" option under the Update setting in Magic Leap Hub > Settings > Package Manager
Hi Kevin, does that remove all the old versions? Is it possible to select only the ones I don't want?
