Capturing images in the same quality as the magic leap 2 camera application
Unity Editor version: 6000.0.58
ML2 OS version: 1.12.1
In our company we are developing an mixed reality application. We want to capture high quality images and video’s within the application. We have it working images do look good (2880*2160) resolution and can capture a video too. Only our video is very low quality compared with the video that would be captured with the on-device application for the camera. (See frame from video below)
The same is done with the on-device camera application and i see in mixed reality that it can capture a high-quality video
My question is: Is this a unity issue or is it that the on-device camera is just better?,
and if so why can’t we use that high resolution in a unity project.
My code/settings for capturing and saving a video on device is:
The ML Video Recorder has been deprecated, however if you choose to continue using it , you can look at the Magic Leap Unity Examples 1.12.0 , which includes an example of capturing video.
Note: Despite it being deprecated we have not had anyone report low video capture quality.
I can see why, the quality is actually verry good when i actually use the right variables, i only set the Bit_Rate not the Parameter_Video_Bitrate now the quality is amazing.
Sooo my bad :grimacing:
