Cannot get Serial Number of the Magic Leap Device using Android System Properties
Unity Editor version: 2022.2.12f1
ML2 OS version:Version 1.2.0
Build B3E.230330.11-R.044
Android API Level 29
MLSDK version:1.7.0
Host OS: (Windows/MacOS): Windows11
Hi
I'm trying to get the Serial Number information of the ML2 device using the following c# code in Unity App
AndroidJavaClass SystemProperties = new AndroidJavaClass("android.os.SystemProperties");
string model = SystemProperties.CallStatic<string>("get", "ro.boot.serialno");
 Debug.Log("Android Model: " + model);
In addition to the Serial Number , I'm also retrieving the ro.build.id build version .
When I run the app in ML2 , It returns the build version but not the Serial Number
I verified that the property name is correct and running the adb shell getprop command returns the value for the "ro.boot.serialno" property
Hi @sageer.nakhawa
Magic Leap 2 is running an Android 10 based operating system. Since Android 10, applications require the android.Manifest.permission.READ_PRIVILEGED_PHONE_STATE permission which is only available to system applications.
Where do I add this , I notice there are 2 manifest files in the project I'm working on .
One under Assets->Plugins->Android and another under Thirdsparty->Plugins->Android
Thanks
Sageer
Do you mean that the application doesn't have the permission to access it at all ?
Correct, getting the devices serial number is not supported.
