Our Unity based app shows up with the app name 'base' under the APP name on the Device Bridge.
That is not the name of the app. The real name of the app shows up correctly in the Magic Leap headset. It appears to be some sort of default name perhaps?
Anyone have any idea where we could find and change this app name string to match our app's actual name? It's a minor detail but I'm hoping it's something simple and obvious.
Thanks!
Can you confirm with a screenshot that you have the correct app name under Player settings here:
Yes I can confirm the Product Name has our app's name (which is not 'base'). The product name also shows up correctly in the launcher on the headset along with the app's icon.
The app name that shows up in the Magic Leap Hub all that needs fixing.
Thanks for looking into that for us. We'll go ahead and log this as a bug and let you know of future developments.
I'm going to reach out to our team to see if there is somewhere that this could be changed manually.
Hi @om-iman,
At this time, there is no workaround for this issue. It is a known issue and is currently being worked on. We expect this to be fixed in the near future and we will keep you updated as changes are made. Thank you so much for your patience.
Thank you very much. It's not a high priority issue, but good to know it's known.
-Iman
