I've recently started using the Universal Render Pipeline's URP Decal Projector component to display some decals on various surfaces in my app. In use, things appear normal in the ML2. However, when I take a video capture from either the ML2 or through the Hub's Capture or Stream tabs, the decals are always invisible.
In the URP Asset's Decal Render Feature, I have tried both the DBuffer and Screen Space technique, both having the same result.
Unity Editor version: 2022.3.56f1
ML2 OS version: 1.12.0
Unity SDK version: 2.6.0-pre.R15
Is there anything I can do to get these Decals to show up in captures?
Thanks
