The Advanced Capture screen does not fit and the buttons in the lower right corner do not appear.
When I go to the Advanced Capture screen help page, it becomes a Not Found page.
https://developer-docs.magicleap.cloud/docs/guides/developer-tools/ml-hub/ml-hub-advanced-capture
Thank you for raising this @tokufxug. I will dig into this and report back asap.
@tokufxug What size resolution is your screen? We're looking at adjusting responsiveness for the Hub.
@tokufxug Thanks again for raising, we're tweaking our Hub to fix this resolution bug. We're also correcting the Advanced Capture help link asap.
