I am trying to capture a frame from magic leap and save it as JPG on the device. I am saving it in the following manner:
yield return new WaitForSeconds(2f);
debugText.SetText("Capturing a Frame");
// Capture a frame
Task<Texture2D> task = imageAcquirer.GetImage();
yield return new WaitUntil(() => task.IsCompleted);
Texture2D frame = task.Result;
if (frame != null)
debugText.SetText("Saving as JPG");
byte[] bytes = frame.EncodeToJPG();
string filePath = Application.persistentDataPath + "/ML2currentFrame.jpg";
File.WriteAllBytes(filePath, bytes);
debugText.SetText("Saved JPG to " + filePath);
The path it is stored into is : /storage/emulated/0/Android/data/com.base64_NoJson.base64_NoJson/files/ML2currentFrame.jpg .. however I cannot find any files in that location.
I believe the file is saved in that location as I was able to access the JPG from the same path and visualize the texture on a raw image.
Can you point me towards how I can access the files being stored locally on the device? Thanks.
