A scene rendering issue has been detected in the App Simulator. See the attached screenshot for an example of the display.
The scene is not rendered completely. When run in the Unity Editor, the objects from the Unity scene are rendered correctly, but the background of the simulator is missing.
The simulator console refers to a problem in OpenGL, but the installed version is higher than required (4.6).
The problem is observed on Intel® Iris® Xe Graphics. Full specification: Intel® Core™ i7-1165G7 Processor
It was also noticed that with the same version configuration, the problem does not appear on the discrete graphics from Nvidia.
Unity Editor version (if applicable): 2022.2.0
MLSDK version: 1.8.0
ML Hub version: 2.0.12.202306052102
Magic Leap Application Simulator (ZI) Runtime version: 3.6.0.20230609
Magic Leap App Simulator for Unity (if applicable): 3.6.0-187.zi3b19841
Host OS: Windows 10 22H2
ZIP logs:
MLHubLogs-20230707-140819-win.zip (140.3 KB)
