MLCameraIntrinsicCalibrationParameters high reprojection error
Hooyah,
ML2 OS version: 1.10.0
MLSDK version: 1.10.0
Host OS: Win
The PNP reprojection error seems too high, especially at the image borders when using the intrinsics provided by MLCameraResultExtras/MLCameraIntrinsicCalibrationParameters.
Below is a clone of my implementation in python that is based on [1]. Could you please quickly double check the 'undist_magic_leap()' function. Maybe i made a silly mistake :wink:
The script outputs around 0.3 pixels RMS error for the small marker. I think that is way too high.
####### Magic Leap intrinsics
Pose in camera frame:
[[ 0.00707712  0.99896557 -0.04491877]
 [ 0.98881859 -0.01368233 -0.14849442]
 [-0.1489554  -0.0433656  -0.98789256]]
[-210.09145112  286.64426796  662.64285839]
Residuals (pixels)
[ 0.27064139 -0.24666436 -0.28740943  0.30538637  0.23132418 -0.31972344
 -0.21509027  0.26071783]
RMS error (pixels)
0.26924121538579704
Python code:
import numpy as np
from scipy.spatial.transform import Rotation as R
from scipy.optimize import least_squares
# Measurements of four corner points of a 45x45mm square
# obtained from the luminance channel (MLCameraOutputFormat_YUV_420_888)
#    cv::Mat image(output->planes[0].height, output->planes[0].width, CV_8UC1, output->planes[0].data);
image_points = np.array(
  [[1128.440, 3056.529],
  [1135.872, 2827.960],
  [922.817, 2827.048],
  [914.213, 3053.972]])
s = 199.6 / 200.0
object_points = s*np.array(
  [[22.5,22.5,0],
  [-22.5,22.5,0],
  [-22.5,-22.5,0],
  [22.5,-22.5,0]])
# MLCameraIntrinsicCalibrationParameters obtained from MLCameraResultExtras
focal_length = np.array([3229.906982422, 3229.008300781])
principal_point = np.array([2041.873, 1554.210])
distortion = np.array([0.102010615170, -0.384192407131, 0.000052323157, 0.000182186413, 0.405351102352])
width = 4096
height = 3072
# https://developer-docs.magicleap.cloud/docs/guides/unity/camera/ml-camera-metadata/
def undist_magic_leap(image_points, width, height, focal_length, principal_point, distortion):
  image_points_undist = np.zeros(image_points.shape)
  K = np.array([distortion[0],distortion[1],distortion[4]])
  P = np.array([distortion[2],distortion[3]])
  pixel_to_normalized = 1.0 / np.linalg.norm(np.array([width, height]))
  for i in range(image_points.shape[0]):
    x = pixel_to_normalized * (image_points[i] - principal_point)
    r2 = np.linalg.norm(x)**2
    r4 = r2*r2
    r6 = r2*r2*r2
    s = x + x * K.dot(np.array([r2, r4, r6]))
    s[0] += P[0] * (r2+2*x[0]**2) + 2.0*P[1]*x[0]*x[1]
    s[1] += P[1] * (r2+2*x[1]**2) + 2.0*P[0]*x[0]*x[1]
    #print(s)
    image_points_undist[i] = s / pixel_to_normalized
    image_points_undist[i] /= focal_length
  return image_points_undist
# PNP objective function, for testing purposes
def pnp_error(x, f, obj_points, img_points):
    r = R.from_rotvec(np.array([x[0],x[1],x[2]])).as_matrix()
    t = np.array([x[3],x[4],x[5]])
    residuals = np.zeros(obj_points.shape[0]*2)
    for i in range(obj_points.shape[0]):
        point_camera = r@obj_points[i]+t
        residuals[2*i] = f[0] * point_camera[0]/point_camera[2] - img_points[i,0]
        residuals[2*i+1] = f[1] * point_camera[1]/point_camera[2] - img_points[i,1]
    return residuals
image_points_undist_leap = undist_magic_leap(image_points, width, height, focal_length, principal_point, distortion)
pose_guess = np.array([ -2.2, -2.2, -0.17, -211, 283, 677])
print("####### Magic Leap intrinsics")
res = least_squares(pnp_error, pose_guess, args=(np.array([1,1]), object_points, image_points_undist_leap))
print("Pose in camera frame:")
x = res["x"]
sol_r = R.from_rotvec(np.array([x[0],x[1],x[2]])).as_matrix()
print(sol_r)
print(x[3:6])
print("Residuals (pixels)")
residuals = pnp_error(res["x"], np.array([1,1]), object_points, image_points_undist_leap)
residuals_pixels = residuals * np.repeat(focal_length,object_points.shape[0])
print(residuals_pixels)
print("RMS error (pixels)")
print(np.sqrt(np.sum(residuals_pixels**2)/(2*object_points.shape[0])))
[1] # Intrinsic/Extrinsic Parameters | MagicLeap Developer Documentation
We can take a closer look, but briefly, which camera are you trying to undistort captured images from? Also, could you please share your capture configuration? (I'm curious about the image format and resolution)
The center rgb camera uses a standard pinhole distortion model. The world cameras use a different distortion model. If you're using the rgb cam and if you're able to make opencv calls, OpenCV's undistort function should correctly undistort images captured from the rgb cam-
https://docs.opencv.org/4.10.0/d9/d0c/group__calib3d.html#ga69f2545a8b62a6b0fc2ee060dc30559d
Adam
Hi Adam,
thanks for the info !
FYI: I used the CV/RGB camera at fullres with the MLCameraOutputFormat_YUV_420_888 format and processed only the luminance plane.
But meanwhile i switched to the World Cameras for which i found some Python code in a forum post: Undistorting World Camera and Depth Camera Images
For the CV/RGB camera the Magic Leap API docs provide a non-iterative undistort function (UndistortViewportPoint) Intrinsic/Extrinsic Parameters which seems to contradict the iterative approach used by OpenCV (and the World Camera).
Cheers
The CV camera does not use this method because it is an example of implementing undistortion in Unity without using a 3rd party library and can be used at runtime.
The two-step iterative undistortion for the equidistant model / world camera works quite well at least for my headset. Is it enough to use a fixed amount of newton iterations (you had num_iters=3 in your python code) or do i have to iterate until convergence ? And is the undistortion guaranteed to converge for each pixel ? Do you test that at manufacturing time for each headset ?
Cheers
I found that using 3 iterations worked well for my experiments but you can use more if you wish.
I'm not sure what you are refering to when you say:
Regarding the calibration, we don't have that information published but I assume that this is correct since some internal algorithms, such as head pose, rely on the accuracy of the world cameras.
The newton iterations for the tangential distortion could diverge theoretically, its just a local optimizer. But in practice it seems to work just fine.
Thx !
