Unfortunately, the Unity forum might be a better place for this type of question since it is not specific to Magic Leap and out of scope for this forum. You may want to consider using the CVCamear pose for the origin of the ray. You can obtain it using the MLCVCamera.GetFramePose  function. For example
   private void OnCaptureRawVideoFrameAvailable(MLCamera.CameraOutput capturedFrame, MLCamera.ResultExtras resultExtras, MLCamera.Metadata metadataHandle)
            if (MLCVCamera.GetFramePose(resultExtras.VCamTimestamp, out Matrix4x4 cameraTransform).IsOk)
              Debug.Log($"Cam Pose: {cameraTransform.GetPosition()}; {cameraTransform.rotation}");
Here is a basic sample of converting a pixel position to world ray. It positions objects that the corner of the image:
                uint width = capturedFrame.Planes[0].Width;
                uint height = capturedFrame.Planes[0].Height;
                Vector2 topLeftPixel = new Vector2(0, 0);
                Vector2 topRightPixel = new Vector2(width, 0);
                Vector2 bottomLeftPixel = new Vector2(0, height);
                Vector2 bottomRightPixel = new Vector2(width, height);
                Vector2 centerPixel = new Vector2(width / 2f, height / 2f);
                TopLeftObject.position = CameraUtilities.CastRayFromScreenToWorldPoint(resultExtras.Intrinsics.Value, cameraTransform,topLeftPixel);
                TopRightObject.position = CameraUtilities.CastRayFromScreenToWorldPoint(resultExtras.Intrinsics.Value, cameraTransform, topRightPixel);
                BottomLeftObject.position = CameraUtilities.CastRayFromScreenToWorldPoint(resultExtras.Intrinsics.Value, cameraTransform, bottomLeftPixel);
                BottomRightObject.position = CameraUtilities.CastRayFromScreenToWorldPoint(resultExtras.Intrinsics.Value, cameraTransform, bottomRightPixel);
                CenterObject.position = CameraUtilities.CastRayFromScreenToWorldPoint(resultExtras.Intrinsics.Value, cameraTransform, centerPixel);
Here is a Utility script you can use to project from the RGB camera pixel position and view port positions.
public class CameraUtilities
    // The length to be used for the ray when no intersection with the WorldMesh is found.
    // This prevents the ray from "popping" or suddenly changing length visually.
    private static float _rayLength = 3;
    /// <summary>
    /// Casts a ray from a 2D RGB Camera pixel position to a point in world space.
    /// </summary>
    /// <param name="icp">Intrinsic Calibration parameters of the camera.</param>
    /// <param name="cameraTransformMatrix">Transform matrix of the camera.</param>
    /// <param name="screenPoint">2D screen point to be cast.</param>
    /// <returns>The world space position where the ray intersects with the WorldMesh.</returns>
    public static Vector3 CastRayFromPixelToWorldPoint(MLCamera.IntrinsicCalibrationParameters icp, Matrix4x4 cameraTransformMatrix, Vector2 screenPoint)
        var width = icp.Width;
        var height = icp.Height;
        // Convert pixel coordinates to normalized viewport coordinates.
        var viewportPoint = new Vector2(screenPoint.x / width, screenPoint.y / height);
        return CastRayFromViewPortToWorldPoint(icp, cameraTransformMatrix, viewportPoint);
    /// <summary>
    /// Casts a ray from a 2D viewport position to a point in world space.
    /// This method is used as Unity's Camera.ScreenToWorld functions are limited to Unity's virtual cameras,
    /// whereas this method provides a raycast from the actual physical RGB camera.
    /// </summary>
    /// <param name="viewportPoint">2D viewport point to be cast.</param>
    public static Vector3 CastRayFromViewPortToWorldPoint(MLCamera.IntrinsicCalibrationParameters icp, Matrix4x4 cameraTransformMatrix, Vector2 viewportPoint)
        // Undistort the viewport point to account for lens distortion.
        var undistortedViewportPoint = UndistortViewportPoint(icp, viewportPoint);
        // Create a ray based on the undistorted viewport point that projects out of the RGB camera.
        Ray ray = RayFromViewportPoint(icp, undistortedViewportPoint, cameraTransformMatrix.GetPosition(), cameraTransformMatrix.rotation);
        // By default, set the hit point at a fixed length away.
        Vector3 hitPoint = ray.GetPoint(_rayLength);
        // Raycast against the WorldMesh to find where the ray intersects.
        // TODO: Add a layer mask filter to prevent unwanted obstructions.
        if (Physics.Raycast(ray, out RaycastHit hit, 100))
            hitPoint = hit.point;
            _rayLength = hit.distance;
        return hitPoint;
    /// <summary>
    /// Undistorts a viewport point to account for lens distortion.
    /// https://en.wikipedia.org/wiki/Distortion_(optics)
    /// </summary>
    /// <param name="distortedViewportPoint">The viewport point that may have distortion.</param>
    /// <returns>The corrected/undistorted viewport point.</returns>
    public static Vector2 UndistortViewportPoint(MLCamera.IntrinsicCalibrationParameters icp, Vector2 distortedViewportPoint)
        var normalizedToPixel = new Vector2(icp.Width / 2, icp.Height / 2).magnitude;
        var pixelToNormalized = Mathf.Approximately(normalizedToPixel, 0) ? float.MaxValue : 1 / normalizedToPixel;
        var viewportToNormalized = new Vector2(icp.Width * pixelToNormalized, icp.Height * pixelToNormalized);
        var normalizedPrincipalPoint = icp.PrincipalPoint * pixelToNormalized;
        var normalizedToViewport = new Vector2(1 / viewportToNormalized.x, 1 / viewportToNormalized.y);
        Vector2 d = Vector2.Scale(distortedViewportPoint, viewportToNormalized);
        Vector2 o = d - normalizedPrincipalPoint;
        // Distortion coefficients.
        float K1 = (float)icp.Distortion[0];
        float K2 = (float)icp.Distortion[1];
        float P1 = (float)icp.Distortion[2];
        float P2 = (float)icp.Distortion[3];
        float K3 = (float)icp.Distortion[4];
        float r2 = o.sqrMagnitude;
        float r4 = r2 * r2;
        float r6 = r2 * r4;
        float radial = K1 * r2 + K2 * r4 + K3 * r6;
        Vector3 u = d + o * radial;
        // Tangential distortion correction.
        if (!Mathf.Approximately(P1, 0) || !Mathf.Approximately(P2, 0))
            u.x += P1 * (r2 + 2 * o.x * o.x) + 2 * P2 * o.x * o.y;
            u.y += P2 * (r2 + 2 * o.y * o.y) + 2 * P1 * o.x * o.y;
        return Vector2.Scale(u, normalizedToViewport);
    /// <summary>
    /// Creates a ray projecting out from the RGB camera based on a viewport point.
    /// </summary>
    /// <param name="viewportPoint">2D viewport point to create the ray from.</param>
    /// <param name="cameraPos">Position of the camera.</param>
    /// <param name="cameraRotation">Rotation of the camera.</param>
    /// <returns>The created ray based on the viewport point.</returns>
    public static Ray RayFromViewportPoint(MLCamera.IntrinsicCalibrationParameters icp, Vector2 viewportPoint, Vector3 cameraPos, Quaternion cameraRotation)
        var principalPoint = icp.PrincipalPoint;
        var focalLength = icp.FocalLength;
        Vector2 pixelPoint = new Vector2(viewportPoint.x * width, viewportPoint.y * height);
        Vector2 offsetPoint = new Vector2(pixelPoint.x - principalPoint.x, pixelPoint.y - (height - principalPoint.y));
        Vector2 unitFocalLength = new Vector2(offsetPoint.x / focalLength.x, offsetPoint.y / focalLength.y);
        Vector3 rayDirection = cameraRotation * new Vector3(unitFocalLength.x, unitFocalLength.y, 1).normalized;
        return new Ray(cameraPos, rayDirection);
