nathan
1
I have to implement Microsoft Authentication next. Just curious if there is a recommended approach or solution for this on the Magic Leap ?
I've been researching possible solutions and Ill be reporting back to the team to assess which one we should use.
Id like to stay away from firebase since its a bit of an overkill to use it for authentication only.
Hi @nathan, one example we've done internally includes Azure AD integration:
- We have an internal Azure AD application and account on Azure AD panel.
- We are using the Azure AD demo app with Microsoft Authentic app on ML2 and we can enable the "share device mode" on ML2.
- After that we can see the ML2 device login on Azure AD panel and we can control the device permission on panel.
- We modified our Azure AD demo app to save the token and user on AOSP AccountManager on ML2.
Please let me know if this helps.
Do I have access to this example?
No it was an internal sample app for testing purposes.
Can I have access to this sample app? Would definitely help
Sorry @nathan unfortunately I'm not in a position to share. Hope the above gives you some direction.
