Magic Leap Examples controller not working
Magic Leap Examples controller not working.
I get the UI with overview, viewmode, viewdistance , quit and other buttons but unable to interact with this UI. the controller doesnt shoot out a ray . I am able to press the home button to restart the app from the home screen but inside the app doesnt work.
Hi @juan.suero.robotics, is this for the AR Brochure app? Thanks.
This is just the samples I downloaded from your developer portal. Getting started
Gotcha, thank you. Let me see if I can recreate the issue now. Also, please restart the device itself and let me know if that helps.
Can you post what versions you're on and attach logs please? Having trouble recreating this.
Unity Editor version::
ML2 OS version: :
MLSDK version: :
Host OS: (Windows 11, MacOS 12.2.1, etc) :
Error:
I needed to update the Magic leap OS to match the samples and everything is lined up it seems.
here is what im working with now.
Version 1.1.0
Build B3E.221128.08-R.092
Android API Level 29
previously i have version 1.1.0-dev-somethingOrOther
