Hi guys.
We are looking to replicate the functionality present both on standard Android Devices and Hololens 2 (both referred as Clients), which is the following.
Client installs an app called Remode Desktop
 https://play.google.com/store/apps/details?id=com.microsoft.rdc.androidx&hl=it&gl=US&pli=1
 Microsoft Apps
Server (A Microsoft PC) is running the REMOTE DESKTOP feature.
 How to use Remote Desktop - Microsoft Support
When connecting, the Server goes to the Windows Hello Login, while client takes control of the PC and is able to remotely manage it.
 On Hololens 2, the Client is a Window, which can be placed in any place and pinned.
Magic Leap 2 is missing a tab/windows management for 2D applications, which is probably one of the most limiting features of the device yet.
What are the plans of implementing the windows management, and the ability to remotely connect to a PC?
As the first is definitely an important cross-industry needed application, the second one opens up the possibility of using the device in scenarios like this one:
which for the Healthcare industry is a KEY feature. To be able to use ML2 (like HL2) as a viewer in the surgical room, connected to a Dynamic Navigation System or a scanner which are managed by a PC situated in the room (but far away from the patient)
