Hi, I’m currently experiencing inconsistent behavior with Debug.Log messages when testing on Magic Leap 2 using Magic Leap Hub 3. Here are the relevant environment details:
- Unity Editor version: 2022.3.22f1
- Magic Leap 2 OS version: 1.12.0
- Magic Leap SDK version: 1.12.0
- Host OS: Windows
Issue Description:
I’m using Debug.Log statements throughout my Unity project for debugging purposes. All my logs are consistently prefixed with [VisualTest], such as:
Debug.Log("[VisualTest] Start");
However, I’m observing the following inconsistent behavior:
- Some logs appear while others do not, even when placed at the very beginning of the
Start()function or at the top of button callbacks. - The scene itself works as expected—UI responds, logic executes—but log messages from active code paths are missing.
- I filtered log output in Magic Leap Hub 3 using message content (e.g., messages containing
[VisualTest]) and also attempted filtering by package name—but:
- Filtering by package name yields no results.
- The log entries show the app’s package with PID, but not the actual package name I set in Unity.
Questions:
- Is this a known issue in Magic Leap OS 1.12.0 or the Hub 3 logging system?
- Is there a more reliable way to filter or ensure logs consistently appear (e.g., toggling developer logging settings)?
- How can I confirm which package name Magic Leap Hub recognizes for log filtering?
Any help or recommendations for more reliable debugging would be greatly appreciated.
Thanks!
