If there is not enough light in the environment (ex in night), the system will stop with a warning "Tracking, do not move". I want to use an application that doesn't require tracking in such environment. Is there a way to turn off the warning? Or please let me know if there is a method that can be used in low light environment.
The Magic Leap 2 requires the device to track the environment to operate properly. Because of this we do not provide a way to disable this warning. However if you provide more details on your use case we can share your feedback with our voice of customer team.
Here is additional information about how the headset tracks it's position: Headpose | MagicLeap Developer Documentation
Thank you for comment.
We want to use MagicLeap2 as map guide in outside whenever it's day or night.
it can be used in daytime, but not in nighttime due to low light level.
