How do I run at 120 hz
How can I run my app at 120 hz?, seems to always just do 60.
I set the frame timing hint to Max 120 in the plugin settings, but it makes no difference, the app just runs at max 60. Using 7.0.0-exp.3
Hi @javier ,
This setting will be removed because the Frame Timing Hint API is being deprecated. Our device is capped at 60hz to help developers achieve stable framerate, even if the application is running for an extended period of time.
The ML2 automatically interpolates between frames. If your app is running at 60 Hz, it will be interpolated and rendered at 120 Hz.
