Has anyone found or built a gRPC.core runtime for Android x86_64? It's an older version of gRPC that is still under maintenance. There are prebuilt binaries for most other targets available in multiple places but not the hardware/OS combination of the ML2. We build our project for a number of other devices and would rather not spend the effort migrating to grpc-dotnet yet.
Unity 2022.3.10f1
Hi @smcintyre
Welcome to the forum.
Just a cursory look on the grpc github seems to suggest that it was compiled for x86, but not x86_64. Other people have suggested compiling from source and including the x86_64 build target, but it is not supported by that team. If that ends up working for you please let me know.
-Sidney
Hey Sidney -
Thanks for the quick response. Yeah I'd seen that same suggestion, was hoping to just find a binary. But I'll do that over the weekend and post here if it works for others. Thanks.
-- Shaun
did it work for you?
if it does, can you provide your code
I got this working for x86_64
libgrpc_csharp_ext.so (14.3 MB)
