Speech to Text - Recommendation
I am looking for a ML2 - android x86_64 - architecture compatible speech to text solution.
We are currently working with Microsoft LUIS, their libs are compiled for Arm and X86 ONLY.
All feedback is appreciated, if i find a solution i will post it here.
Thanks,
I
Thank you for your post, @istvan. I'm interested in what the community may recommend. I'll also look into this as well, and will share any helpful insight.
Hi @istvan, have you found anything in your search? Anything on the Unity Asset Store? The key to Magic Leap compatibility is ensuring Android x86_64 is supported, so you're looking for the right specs. Please keep us updated. Thanks very much.
@istvan Was wondering if you had any luck with this as I am very interested as well?
@istvan and @kdowney I am also interested in a speech-to-text solution. Are there any new insights?
