We run in the tethered mode and have been trying to find a way to charge the ML2 while it is tethered. None of the power hubs that we’ve tried have worked. Are there any known power hubs that support ML2 charging and tethering together?
For this we recommend using adb over wifi. So that your device can remain connected even when the USB port is being used for charging
We use the “CG-UCUSBPDB” Type-C to B PD Injector. Just don’t try to install OS updates with it.
Thank you. That had not turned up in any of my searches.
The solution is working well for us.
