Unity Editor version: 2022.3.5
ML2 OS version:
MLSDK version: 1.9.0
We successfully create webrtc session between ML2 and MacOS app (using Unity WebRTC 3.0.0 pre6) we can see stream from ML MR camera etc... all working perfectly.
we want to allow client control resolution and framerate of ML MR camera from Mac. What is the best way to do this? Do we need restart webrtc session completely or we can recreate MediaStream on ML2 and remove old media tracks and add new ones? I assume we need disconnect old MLCamera and connect new one with new resolution?
