I see 'mlpackageverifier' rejection in Logcat when running native code [Windows, native API v1.3.0-dev1/v1.3.0-dev2/v1.4.0-dev1]:
2023-10-09 23:10:48.198 5744-5744 MLPackageV...::Verifier com.magicleap.mlpackageverifier E Package com.magicleap.revok signature not match
2023-10-09 23:10:48.198 5744-5744 MLPackageV...::Verifier com.magicleap.mlpackageverifier E Reject package: com.magicleap.revok permissive=1
I see this with my own apps, and while compiling the native API examples.
I have tried cleaning
./gradlew clean
cache invalidation, uninstalling the apps on device:
adb uninstall com.magicleap.revok
Strangely, deleting the signingConfigs block altogether omits the ‘signature not match’ if we do a Gradle sync before each build, but otherwise I cannot see a change app behavior.
In Android Studio I refactored the signature to ensure our given package to com.magicleap.revok is consistent in Java, C++, ‘activity_main.xml’, ‘build.gradle (:app)’, applicationId "com.magicleap.revok" and ‘AndroidManifest.xml’.
ML2 APIs seem to require special signing -- is there any reference?
Signing config in 'build.gradle' from the sample projects is as follows:
> signingConfigs {
> release {
> keyAlias keystoreProperties['keyAlias']
> keyPassword keystoreProperties['keyPassword']
> storeFile file(storeFilePrefix + keystoreProperties['storeFile'])
> storePassword keystoreProperties['storePassword']
