SceneView AR/3D compiles and runs for us on Android devices (including Pixel 7) but halts early in execution on ML2; logcat notes panic in ‘generateMipmaps:396’ for the reason that “Texture format 40 is not mipmappable.”
Is anyone familiar with 'Texture format 40' as a term relating to the ML2 APU?
Did Magic Leap 2 support that feature in the first place?
Magic Leap 2 uses the Android OS, but I don't think that means the same thing as the availability of Android features for smartphones and other devices.
@tokufxug, I wrote about running software (SceneView) on ML2. What do you mean by a 'feature'?
It looks like SceneView AR mode requires ARCore : GitHub - SceneView/sceneview-android: SceneView is a 3D and AR Android Composable and View with Google Filament and ARCore. This is a Sceneform replacement in Kotlin which is not supported by Magic Leap 2.
Secondly, ETC2 is not support on Magic Leap. Instead use DXT or DXT + BC4/BC or DXT + BC4/BC
Thanks @kbabilinski -- interestingly, I was able to build and run on ML2 fine by altering the lighting model slightly.
