Unity Editor version: 2022.2.21
ML2 OS version: 1.3.0 Dev 2
MLSDK version: 1.8.0
Host OS: Windows 10
Hey everyone, I'm trying to change a script to send captured audio data. The original code uses the Microphone in this manner in various methods.
AudioClip recording;
int lastPosition;
if (!Microphone.IsRecording(null))
recording = Microphone.Start(null, true, bufferSeconds, audioSampleRate);
int lastPosition = Microphone.GetPosition(null);
How can I retrieve this same data using the MLAudioInput integration?
Also is there a method similar to Microphone.End to stop microphone use on Destroy?
Thanks for your help.
Hi @rcazzy1,
Welcome to the Magic Leap 2 developer forums. We are so happy to have you here engaging with us.
Is the Microphone class that you're using not a part of the Magic Leap API? Are you trying to transform that code to use the Magic Leap API? Just looking to clarify here.
Hello! Yes, it seems that the Microphone class is not having any effect in build, and I was looking to use the MLAudioInput system in its place, but I'm a bit lost as to how it can be used in the same manner as the Microphone class.
In the Magic Leap Examples project there is a scene called AudioCapture and it uses the following script to capture and record audio. I would like to point out the StartMicrophone() and StopCapture() methods. Let me know if this is helpful.
// %BANNER_BEGIN%
// %COPYRIGHT_BEGIN%
// Copyright (c) (2019-2022) Magic Leap, Inc. All Rights Reserved.
// Use of this file is governed by the Software License Agreement, located here: https://www.magicleap.com/software-license-agreement-ml2
// Terms and conditions applicable to third-party materials accompanying this distribution may also be found in the top-level NOTICE file appearing herein.
// %COPYRIGHT_END%
// %BANNER_END%
using System.Collections;
using System.Linq;
using UnityEngine.InputSystem;
using UnityEngine.UI;
namespace MagicLeap.Examples
/// <summary>
/// This class uses a controller to start/stop audio capture
/// using the Unity Microphone class. The audio is then played
/// through an audio source attached to the parrot in the scene.
/// </summary>
public class AudioCaptureExample : MonoBehaviour
public enum CaptureMode
Inactive = 0,
Realtime,
Delayed
[SerializeField, Tooltip("The reference to the place from camera script for the parrot.")]
private PlaceFromCamera _placeFromCamera = null;
[SerializeField, Tooltip("The audio source that should replay the captured audio.")]
private AudioSource _playbackAudioSource = null;
[SerializeField, Tooltip("The text to display the recording status.")]
private Text _statusLabel = null;
[Space]
[Header("Delayed Playback")]
[SerializeField, Range(1, 2), Tooltip("The pitch used for delayed audio playback.")]
private float _pitch = 1.5f;
[SerializeField, Tooltip("Game object to use for visualizing the root mean square of the microphone audio")]
private GameObject _rmsVisualizer = null;
[SerializeField, Min(0), Tooltip("Scale value to set for AmplitudeVisualizer when rms is 0")]
private float _minScale = 0.1f;
[SerializeField, Min(0), Tooltip("Scale value to set for AmplitudeVisualizer when rms is 1")]
private float _maxScale = 1.0f;
private Material _rmsVisualizerMaterial;
private bool hasPermission = false;
private bool isCapturing = false;
private CaptureMode captureMode = CaptureMode.Inactive;
private string deviceMicrophone = string.Empty;
private int detectionAudioPosition = 0;
private readonly float[] detectionAudioSamples = new float[128];
private bool isAudioDetected = false;
private float audioLastDetectionTime = 0;
private float audioDetectionStart = 0;
private float[] playbackSamples = null;
private const int AUDIO_CLIP_LENGTH_SECONDS = 60;
private const int AUDIO_CLIP_FREQUENCY_HERTZ = 48000;
private const float AUDIO_SENSITVITY = 0.02f;
private const float AUDIO_CLIP_TIMEOUT_SECONDS = 2;
private const float AUDIO_CLIP_FALLOFF_SECONDS = 0.5f;
private const int NUM_SYNC_ITERATIONS = 30;
private const int NUM_SAMPLES_LATENCY = 1024;
private MagicLeapInputs mlInputs;
private MagicLeapInputs.ControllerActions controllerActions;
private MLAudioInput.StreamingClip mlAudioStreamingClip;
private MLAudioInput.BufferClip mlAudioBufferClip;
void Awake()
if (_playbackAudioSource == null)
Debug.LogError("AudioCaptureExample._playbackAudioSource is not set, disabling script.");
enabled = false;
if (_statusLabel == null)
Debug.LogError("AudioCaptureExample._statusLabel is not set, disabling script.");
enabled = false;
if (_placeFromCamera == null)
Debug.LogError("AudioCaptureExample._placeFromCamera is not set, disabling script.");
enabled = false;
if (_rmsVisualizer == null)
Debug.LogError("AudioCaptureExample._rmsVisualizer is not set, disabling script.");
enabled = false;
MLPermissions.RequestPermission(MLPermission.RecordAudio, permissionCallbacks);
_rmsVisualizerMaterial = _rmsVisualizer.GetComponent<Renderer>().material;
mlInputs = new MagicLeapInputs();
mlInputs.Enable();
controllerActions = new MagicLeapInputs.ControllerActions(mlInputs);
controllerActions.Bumper.performed += HandleOnBumperDown;
controllerActions.Trigger.performed += HandleOnTriggerDown;
// Frequency = number of samples per second
// 1000ms => AUDIO_CLIP_FREQUENCY_HERTZ
// 1ms => AUDIO_CLIP_FREQUENCY_HERTZ / 1000
// 16ms => AUDIO_CLIP_FREQUENCY_HERTZ * 16 / 1000
playbackSamples = new float[AUDIO_CLIP_FREQUENCY_HERTZ * 16 / 1000];
void OnDestroy()
StopCapture();
controllerActions.Bumper.performed -= HandleOnBumperDown;
controllerActions.Trigger.performed -= HandleOnTriggerDown;
mlInputs.Dispose();
private void Update()
VisualizeRecording();
VisualizePlayback();
if (captureMode == CaptureMode.Delayed)
DetectAudio();
UpdateStatus();
void OnApplicationPause(bool pause)
if (pause)
StopCapture();
private void StartMicrophone()
if (!MLPermissions.CheckPermission(MLPermission.RecordAudio).IsOk)
Debug.LogError($"AudioCaptureExample.StartMicrophone() cannot start, {MLPermission.RecordAudio} not granted.");
if (captureMode == CaptureMode.Inactive)
Debug.LogError("AudioCaptureExample.StartMicrophone() cannot start with CaptureMode.Inactive.");
_playbackAudioSource.Stop();
var captureType = MLAudioInput.MicCaptureType.VoiceCapture;
isCapturing = true;
switch (captureMode)
case CaptureMode.Realtime:
mlAudioStreamingClip = new MLAudioInput.StreamingClip(MLAudioInput.MicCaptureType.VoiceCapture, 3, MLAudioInput.GetSampleRate(captureType));
_playbackAudioSource.pitch = 1;
_playbackAudioSource.clip = mlAudioStreamingClip.UnityAudioClip;
_playbackAudioSource.loop = true;
_playbackAudioSource.Play();
break;
case CaptureMode.Delayed:
mlAudioBufferClip = new MLAudioInput.BufferClip(MLAudioInput.MicCaptureType.VoiceCapture, AUDIO_CLIP_LENGTH_SECONDS, MLAudioInput.GetSampleRate(captureType));
_playbackAudioSource.pitch = _pitch;
_playbackAudioSource.clip = null;
_playbackAudioSource.loop = false;
break;
private void VisualizeRecording()
_rmsVisualizerMaterial.color = (Time.time - audioLastDetectionTime < 0.05f) ? Color.green : Color.white;
private void VisualizePlayback()
if (_playbackAudioSource.isPlaying)
_playbackAudioSource.GetOutputData(playbackSamples, 0);
float squaredSum = 0;
for (int i = 0; i < playbackSamples.Length; ++i)
squaredSum += playbackSamples[i] * playbackSamples[i];
float rootMeanSq = Mathf.Sqrt(squaredSum / playbackSamples.Length);
float scaleFactor = rootMeanSq * (_maxScale - _minScale) + _minScale;
_rmsVisualizer.transform.localScale = new Vector3(scaleFactor, scaleFactor, scaleFactor);
else
_rmsVisualizer.transform.localScale = new Vector3(_minScale, _minScale, _minScale);
private void StopCapture()
mlAudioStreamingClip?.Dispose();
mlAudioStreamingClip = null;
mlAudioBufferClip?.Dispose();
mlAudioBufferClip = null;
// Stop audio playback source and reset settings.
_playbackAudioSource.time = 0;
/// <summary>
/// Update the example status label.
/// </summary>
private void UpdateStatus()
_statusLabel.text = string.Format("<color=#B7B7B8><b>Controller Data</b></color>\nStatus: {0}\n", ControllerStatus.Text);
_statusLabel.text += "\n<color=#B7B7B8><b>AudioCapture Data</b></color>\n";
_statusLabel.text += string.Format("Status: {0}\n", captureMode.ToString());
private void DetectAudio()
// Analyze the input spectrum data, to determine when someone is speaking.
float maxAudioSample = 0f;
while (true)
int readSampleCount = mlAudioBufferClip.GetData(detectionAudioSamples, detectionAudioPosition, out int nextPosition);
if (readSampleCount == 0)
break;
detectionAudioPosition = nextPosition;
maxAudioSample = detectionAudioSamples.Take(readSampleCount).Append(maxAudioSample).Max();
if (maxAudioSample > AUDIO_SENSITVITY)
audioLastDetectionTime = Time.time;
if (isAudioDetected == false)
isAudioDetected = true;
audioDetectionStart = Time.time;
else if (isAudioDetected && (Time.time > audioLastDetectionTime + AUDIO_CLIP_TIMEOUT_SECONDS))
var audioDetectionDuration = Time.time - audioDetectionStart;
_playbackAudioSource.clip = mlAudioBufferClip.FlushToClip();
_playbackAudioSource.time = _playbackAudioSource.clip.length - audioDetectionDuration;
// Reset and allow for new captured speech.
/// <summary>
/// Responds to permission requester result.
/// </summary>
/// <param name="result"/>
Debug.LogError($"AudioCaptureExample failed to get requested permission {permission}, disabling script.");
UpdateStatus();
enabled = false;
hasPermission = true;
Debug.Log($"Succeeded in requesting {permission}.");
private void HandleOnTriggerDown(InputAction.CallbackContext inputCallback)
if (!hasPermission)
if (!controllerActions.Trigger.WasPressedThisFrame())
captureMode = (captureMode == CaptureMode.Delayed) ? CaptureMode.Inactive : captureMode + 1;
// Stop & Start to clear the previous mode.
if (isCapturing)
StopCapture();
if (captureMode != CaptureMode.Inactive)
StartMicrophone();
private void HandleOnBumperDown(InputAction.CallbackContext inputCallback)
StartCoroutine(nameof(SingleFrameUpdate));
private IEnumerator SingleFrameUpdate()
_placeFromCamera.PlaceOnUpdate = true;
yield return new WaitForEndOfFrame();
_placeFromCamera.PlaceOnUpdate = false;
In this circumstance, would the StreamingClip be more suited to capturing audio in realtime and sending that data to a server (as I require a ByteString using WavUtility.ConvertAudioClipDataToInt16ByteArray then ByteString.CopyFrom)? Or the BufferClip? The distinction isn't very clear in this code or the documentation and the use case for each.
I would try using BufferClip first and sending the audio using mlAudioBufferClip.FlushToClip() which will return a unity AudioClip. When using StreamingClip it can be used in realtime as it is in the example and can be streamed at any point by accessing streamingClip.UnityAudioClip.
line 201 in AudioCaptureExample.cs
When running this on the ML2, you can hear the clip while it is being recorded.
The BufferClip batches all of the samples together and creates an AudioClip that is played back in its entirety after it has finished recording.
Unfortunately, I'm not familiar with the WavUtility class but it seems like its looking for a complete audio clip but both BufferClip and StreamingClip will contain the audio that is being captured.
I will reach out to the team and let them know of your feedback regarding the verbosity of the documentation.
Thank you,
