I'm not sure whether it's appropriate to ask - but how is transparency implemented in Magic Leap 2? I have the following observations:
- If set an
LitMaterial to be opaque, we are still able to see real-world objects behind it.- If using the "transparent" option, even if set alpha to be 255, still able to see the object behind
- If disable "auto brightness" and manually adjust the brightness level, the object behind cannot be seen when using high enough brightness level.
- When luminance level of the room is high, still will be able to see the object behind.
- Auto brightness seems to decrease the brightness when room luminance level is decreased, and it kind of keep the object behind always visible to us as long as there's at least "some" light in the room.
Considering the nature of optical see through devices, I'm a bit confused of whether brightness adjustment is kind of doing the same thing as adjusting transparency level. For example, would it essentially be the same, as for ML2 implementation, when we (1) increase the value of the Alpha channel of a material and (2) increase the brightness of that virtual object, or the entire scene (if there's only one virtual object in the scene).
I'm referring to this link when I try to model transparency implementation. s ML2 essentially decreasing the amount of light coming from the virtual object to a user when the object is made to be more transparent, which is similar to making it less bright?
If that kind of a question isn't appropriate, maybe my equivalent question is, would it be the same, when the environmental light is controlled at the same level, to (1) increase the brightness and (2) decrease the Alpha value of that material? I'm not very familiar with physics, but based on a conversation with a friend this seems to be possible. If would be very helpful if you could answer my question.
BTW, I have tried your segmented dimming feature and that's really cool. I can see how it blocks light from a certain location that we could control. Then maybe a "opaque" game object, given that it's not actually completely blocking my view to the real world, isn't really blocking light?
Thanks in advance!
